Any updates?
Any updates?
Please don't turn your roof into an antenna farm. (;->) We call these porcupines and the ham owners whackers.
Attachment 17525
Imax 2K working fine, 10/11/12/15/18, 18 needs tuner help 1:2.2 or so.
Already worked the world round on 15 in FT-8 ausies New Zealand China, Thailand South Africa, South America, USA, canada just need 4 states to have worked all USA states.
On 10 a few nice ones when the band was a bit open.
Running 18 meters very low loss Aircom + to it, overkill coax but hey it was here to be used...
Tried Amplifier, Heathkit SB 1000 running 800 watts on 15 , 12 , 10 working fine as the old one did.
SWR on the bands lower as 1: 1.5 worst swr, most 1: 1.2.
There's a bumper under that duct tape? Rest assured in a few months that tape weathered off and he regretted using indoor tape outdoors. You mean hedidn't want to put MORE holes in it, you're looking right at one. That was Dayton 2008, I was there in 2000 IIRC the last one before the roof fell in, no porkies to be seen BUT I just HAD to get a picture of my evil twin brother. I was SO embarrassed, point, shoot, split!
So Cor you're doing fine with the newly repaired Imax, that's GREAT! According to NAVPERS, US Navy radio training manuals I had back in the day, tube transmitters with pi network outputs tolerated well SWR up to 3:1. Well, if it's military it's built to withstand an atomic bomb! My last job was electrical quality control in process and final for a company making magnetic components, transformers, chokes, etc. for military applications, you wouldn't believe how tight tolerances are. I wouldn't worry about a 1:1.5 SWR, that's only a 50 ohm transmitter looking into a 75 ohm load like a dipole. Using a trusty Bird 43 in line watt meter you see actual forward and reflected watts, then use the SWR conversion chart if that really matters.
I have a few pics of it and similar vehicles from the 2004-2015 Dayton era. One of the locals also has a car festooned with at least a couple dozen antennas. The guy is into 2-way radio in a professional capacity and as a prospective customer I'd run in the opposite direction were that vehicle to pull in to my facility for purposes of a quote.
Daiwa CN 801 real PEP reading meter used modified so it shows SWR also in pep mode.
The Heathkit doesn't care on 18 with that SWR, i watch the current back off a little and let it rip, the new 3-500ZG gets nice red during the work.
On the 77 feet high vertical i use the MFJ998 legal limit autotuner for 160 to 20.
So i have on all HF bands the choice of vertical or horizontal antenna use with the Fritzel FD-4 with coil and wire on the short end for 160 to 6 meters.
My roof did look like a porcupine several verticals, 23 element 70 cm beam 12 element 2 meter beam 5 element 6 meter beam, took the beams down getting too old to maintain them and rotor and bearings.
Will add omnidirectional 2/70 horizontal antenna this summer, then i'm done, the Diamond X 510 N works fine in FT 8 but i need horizontal for SSB on 2/70.
Pictures on qrz.com from he old situation.
