Post Deleted
Post Deleted
Tell them it's a 3rd of a wavelength over a half wave dipole ie; operating in colinear mode.
If you can't dazzle them with sparkly baubles, baffle them with Bullshit.
Make the top section 93ft overall, change the ladder-line length to around 44ft and get coverage of 40-20-17-12-10M with <2.1 VSWR. Feed with 1:1 current balun and LMR400 or better to the radio. I use RG-213 with mine.
Doublet.
Which reminds me, I dropped one side of the G5RV to move the camper out and the boy ran it over with the mower. I sat out in the yard in front of the fire pit last night considering what to do next. I'm thinking I can convert the G5RV to a G5RV Jr easily enough, but as long as I've got it down, maybe I'll replace it with an inverted L. No particular reason, I'm just bored by the current lash-up and feel the need to try something different.
If you wish to educate them, and if they wish to be educated, you tell them this:
Dipoles (with impedances of roughly 75 ohms) are odd half-wavelengths. 1/2, 3/2, 5/2, etc. Even half-wavelengths (1 wave, 2 wave, etc.) have an impedance approaching infinity.
That's why a 40 meter dipole works on 15, but not on 10 or 20. (That's sans tuner/matching network, of course)
If you don't wish to do so, or (more likely) they don't wish to learn, then just say 'dipole' and don't bother them with the details.
...and if it's hung as an inverted V instead of a true in-the-plane dipole, the impedance is roughly 50 ohms. And THAT is why most radio grade coax that we use is at or near one of those two impedances...
"Which reminds me, I dropped one side of the G5RV to move the camper out and the boy ran it over with the mower. I sat out in the yard in front of the fire pit last night considering what to do next."
Throw the kid in the fire pit and throw the mower in after him. With that out of the way put up the antenna of your choice.
http://i104.photobucket.com/albums/m.../teddybear.png
At 35 feet, a flat top 3/2 wave 10M dipole has a teddy bear pattern. Aw. So cute. But remember. Don't feed the bears.
