This is becoming an almost daily occurrence...
Attachment 12445
I've got to find a way to make it as plain as the nose of their faces, because apparently I'm doing something wrong. :roll: :wall:
Attachment 12445
Usually I pick these up because it's easier to work them than have them chewing up your receive cycle overpowering any DX. The other reason is they occasionally need you for WAS or some other award.
I have never called to a station calling for DX, but I have seen plenty of other hams doing it.
I refuse to do that. All it does is encourage others to interrupt you. Once you start down that road, you can kiss all the DX goodbye, as one after the other pesters you. I've either shut down, or changed bands on these guys when they don't get the hint.
I know WHY they're doing it. Doesn't change the fact that it's still rude.Quote:
I play ham radio on my terms. If they refuse to understand that, then I simply go do something else. They need me; I don't need them. I don't chase paper.
So have I, and I won't be an enabler to bad behavior. It's like those assholes who, when the DX says, "The WA4?", and 3 guys call who aren't even remotely a WA4. Jackasses....Quote:
Different philosophies, it's all good.
Send "UP LID" via CW in return? :chin:
The first two things I always do are A. Cycle the power, and B. The 1 inch drop. Just pick up the corner and lift it 1 inch and let it fall. 1.5 is too much and 1/2 is too little. 1 inch solves problems. If that fails you just might have to breakdown and read the manual but, only as a last resort. That kind of torture must not be undertaken lightly. I believe that the writers they hire to write these things these days are hired on their ability to write grammatically correct inscrutable prose and grammatically correct is optional.
I would like to think that my advice might help but, sadly, it's unlikely.
More likely is you might find it mildly amusing and that could brighten your day slightly
Good luck
Archie N8OBM
"That kind of torture must not be undertaken lightly."
That's why I always say if all else fails read the instructions, the key words being IF ALL ELSE FAILS. When it comes to a construction project, especially kit building, those key words also apply. If at first you don't succeed try a bigger hammer, but IF ALL ELSE FAILS dynamite always works. This always applies to metalwork, that's why it's called drilling and blasting. Software however is the world's greatest mystery, so another saying applies; if all else fails, fukit.
