Hmmmm........
Hmmmm........
I'm still scratching my head trying to figure out how the fuck you get RF into a DSL modem when on a dummy load. Is the modem sitting on top of the dummy load?
What kind of dummy load is this?
No, the modem is at the end of the house (about 40 feet away) and not near the antennas or feedlines. The phone lines might cross the feedlines in the basement. I am sure they do.
BTW, since putting the T130-2 on the power line to the modem the Dummy load does not cause problems.
EDIT: The Dummy Load is an old Drake DL-300....300W if I remember correctly.
I don't walk well and can usually get down the basement stairs but then have to crawl up them. Some days I do better, so the nest time I'm feeling spry, I'll go down there and have a look.
My wife is afraid I'll fall down the stairs and I have but I've always been at the bottom when I did. 1 or 2 stairs is only a bump.
Well, it's a combination.
Many things are somewhat resistant to this sort of thing, either through purposeful design, or by accidental design. I think it's a crappy design for the Westell modem, coupled with a less-than-perfect (Not saying defective, just not-perfect) electrical grounding system.
My DSL modem kicked over every time I keyed up on 30M, until I added toroids to the power lead. Yes, I have a less-than-perfect electrical ground, and less-than-perfect station setup.
As for the crap design, there's a reason they can give away those modems. A DSL interface for a piece of Cisco gear runs about $400 bucks. And, it's just a small card like this:
http://www.cisco.com/en/US/prod/coll...04_26_05-1.jpg
But it will NEVER have an RFI issue, no matter how crappy the station is setup. Given the fact that DSL uses HF frequencies, it's not all that surprising a cheaply designed interface will have issues. Cable uses UHF, if I recall correctly.
If you have an old AM portable, yank out the ferrite bar antenna, remove the coil, and wrap the telco wire around it.
For a "cheap" potential fix. A friend who got horrible RF into his computer speakers used 'em, and this fixed it.
Well, I got to thinking about it and realized the Phone Companies Drop from the pole was about 20 feet away from the OCFD running parallel with it, and only 2 or 3 feet away from my Butternut. I placed 5 of the snap on ferrites on the phone line where it enters the house and my problem appears to be resolved.
Thanks for all of your help!
