Damn, that gave me a boner.
Mine was working perfectly, until the tip of the spark plug bumped the gas meter pipe.
Ever since then it starts okay, but dies shortly after the actual mowing starts.
If I hit the primer several times, then it will run (raw gasoline cleans the gap?).
I'm going to try a new spark plug, as I suspect that that's the problem.
I would bet the carb is clogged up and just needs to be cleaned and the fuel lines replaced. Its not hard, and is very common due to the type of gas we are forced to use. Best thing to do is empty gas tank at end of season, and run engine until all residual fuel has been burned. Sta-bil fuel additive is your friend.
Briggs & Stratton? Black smoke is usually from unburned gas, oil smoke is usually lighter in color. Replace the gasket and diaphragm between the gas tank & carburetor. It's cheap, about $3. My walk behind (slightly newer at 8 years old) did the same thing. Replacing that diaphragm did the trick...
Or you can install a cataclysmic perverter!!! :shifty:
I get no kick from propane
Liquified gas is a pain in the ass
So tell me why it'd be true
That I get a kick from O2
You're not a fan of the Asylum street spankers, are you?
