The 80/40m will be fed with a choke. The folded dipole will be fed with a quarter wave of twinlead that connects to a balun that connects to coax to the shack.
So....ahhh...barkeep, have you gotten anything in the air yet?
Dave: What's the status of your '902? Is it ready for air play?
Sounds like we have the makings for a nice vintage Yaesu round table here. :think
I have the current 80m ant that is resonant at about 3.6mhz. The homemade choke is resonant at 6m but I think that signal goes straight up. I want to replace this antenna but it did go West to about Dave's territory on 65 watts. SSW and NNE it was very strong. I will use just about the same set up but with heavier wire and a higher feed point. I also want to get the highest point of the antenna up higher. All my good woven nylon rope is gone though, fishing in the mountains off steep banks one season, so I will need to pick up some more of that.Quote:
Originally Posted by N8YX
Fling fishing line over trees. Pull rope up through flung path. Repeat process over next sections until the rope path is laid out. Attach wire to far end and pull. I may have to set up a support mast in the front yard where the bird feeders hang.
Last week my GF brought home an above ground pool, used, so guess what gets priority? The algae was a beautiful shade of green.
Stay buff, poolboy. :rofl:
We'll see how all the dog walking works out. Oops, time for oatmeal.
I have not even started on the 902. Antenna projects are more pressing, but I did get the scope, and I need to get the driver tube tested, I already tried a known good 6146.Quote:
The radio deserves a thorough going through, but it seems to receive just great. I have to look and see if it has the 6KHZ AM filter in it, and want to use it on AM. But I refuse to get a wowipop mic. :rofl:
I am pretty casual about my Ham Radio projects these days. Still skiing and motorcycling. Yard needs a ton of work. Eh?
Keep your pool hand strong...Quote:
Originally Posted by KG4CGC
:rofl: :rofl: :rofl: http://i25.photobucket.com/albums/c7...g-DumbBell.jpghttp://i25.photobucket.com/albums/c7.../g-BarBall.jpghttp://i25.photobucket.com/albums/c7...cleMachine.jpghttp://i25.photobucket.com/albums/c7.../g-GymBike.jpgQuote:
