Originally Posted by
VK3ZL
G'day Corey....I wonder if you have considered using a 40 meter dipole fed with 1/4 wavelength open wire feeders and a balanced tuner? With this set up you can then tune 20, 15, and 10 meters....Probably also the WARC bands as well....No more wire tangles and sorting out each antenna with the coaxial fed fan....Many of these old ideas have been lost in recent years and yet it is the simplest way to get on multi bands with the least bother....I would look at building a link coupled tuner....For 40-10 meters a simple inductor say 12uh, a parallel 75pf transmitting capacitor if you run more than 100 watts, and a few turn coupling link over the center of it with a series old 3 gang broadcast gang...You could breadboard this with a few alligator clips to select tappings for each band and you have the world at your feet...The 40 meter dipole then becomes 1 wavelength at 20 meters and so on up the spectrum...No more multiple wires all over the place..:chin:
Bob..VK3ZL..
