Re: Maintenance day for our repeater (antenna's)
Quote:
Originally Posted by PA5COR
Quote:
Originally Posted by KG4CGC
The view is nice and on a clear day, they say you can see parts of Europe.
If you look from your window, you can see Cuba? :snicker:
Take care,
Cor
I'm not close enough to Cuba but from Mt. Mitchell, the tallest peak east of the Mississippi River you can "see" 5 states, some say 7.
Here is a snap I took from just above an extruded rock formation called Chimney Rock. It doesn't really resemble a chimney from the ground but they certainly couldn't name it ****s Rock. Elevation were I was standing was about 6000 feet.
http://i25.photobucket.com/albums/c7...itchresize.jpg
Nice picture...
I only see that on holliday in France/Germany ....
I'm afraid the Powys repeater site is a mere pimple, about 1400ft/430m ASL, and the mast, which I understand to have been truncated, about 120ft/37m. It's had stainless steel guys and lower fittings and is shared with one or two commercial concerns, notably water.
^thanks for the info ;)
Our flat is just 8 meters ASL, from there the antenna base is 54 meters above the ground level.
But the surrounding area is flat like a pancake :D
