Originally Posted by
K7SGJ
This one was a Walkera 5#10. I've had it awhile, and decided to pull it out and fly it around outside. It's kind of a tween. A little big for inside, and a little small for outside. Yes, I've tried all the common stuff, and batteries were the first thing I tried as I have several extras. I think what happened, is when it hit the antenna, it damaged the inner rotor shaft. It's a coaxial unit, and the lower blades seem to spin out okay, but the upper seems very sluggish. At least it seems that way. I am trying another rotor shaft assembly to see what happens. It really acts like what you would expect if the motor gear and drive gear didn't have enough clearance, but that isn't the problem. I'll let you know what it turns out to be.
