How was that receiver? From the description it sounds like an AR-3 with an RF stage and a product detector. How was sensitivity above 14 Mc?
I wish they still made kits like these :(
I'd like to find a kit for AMBCB. Not some cheap ass version of a modern portable for 11 bucks. Something I could do some AMBCB DX with.
Look up the "Spiderweb" receiver project which appeared in an old Elementary Electronics magazine of the late '70s. If I still have the issue I'll make a photocopy for you.
As an alternative: Look for an ITT Mackay 3031A/AR or 3041A/AR. Maybe a 3030A/AR if you don't mind tuning with a decade-based thumbwheel switch arrangement. I have one each 3030AR and 3031A - they are definitely the hot ticket when it comes to AM BC DX. The only features missing are an IF shift and notch filter but one could use an external audio-based unit for the latter.
Well, I do still have my Hammarlund SP-600. That's one hell of a receiver for AMBCB. I also tune around AMBCB with a Yamaha CT-410II. That's how I made my first Canadian catch. It's the best solid state receiver for both AM and FM that I've ever used.
I was wondering about a kit I could experiment with. Probably more of a Winter project. These days I'm riding and reading up of scooter mods. Just found a service manual so I'm thinking of attacking the valve lash and the drive belt. I'm pretty sure that 15,000 miles that they claim the belt is supposed to last is an exaggeration. It might go that long, but not well.
As it turns out, I got more than just a brochure at Deerfield. I got the whole manual for the one-tube radio. Am going to scan it for the web (looking for a round tuit now). That would make a fun project....especially the part about finding the parts at hamfests. It's construction is fahnstock clips on a piece of plywood. Doubt that DX'ing is what that'll be good for, tho.
http://www.tubesandmore.com/cemirror...11-4034-TH.GIF
I saw an article in CQ for a one tube "peanut whistle" crystal controlled transmitter. 117N7GT tube, designed so that it didn't need a transformer or anything else.
I was young enough to not know better. I used a cardboard shoebox. All I had available at the time.
Damn thing worked, too.
However, nothing was soldered (my dad didn't trust me with a soldering iron then... well, at least not his, but he used them to create sculptures, not fix electronics, can you say "acid core solder"?) and my younger brother had to play with the wiring... first time I ever blew up some electrolytic capacitors.
One of these days, I need to find that schematic and rebuild that. I already have another tube, I do need to find a socket for it...
On Edit: A little research reminded me that the article I was referring to was called "The Peanut Whistle" and it was in the August 1965 issue of CQ. Never did find a copy of the article, though.
...and, no sooner do I post that, a quick search finds a copy on eBay for a couple of bills. I remember the issue now, it featured astronaut Owen Garriot W5LFL on the cover. Should have it in a couple of days...
I found one of those 30 in 1 kits a few years ago from RS at a garage sale for $2. It had the parts mounted inside little clear plastic cubes that popped into place. They had open bottoms to help them fit into the board/frame better. I made a little AM transmitter that broadcast all the way down to the LW aviation beacon band! Whoops! I thought I was on 1590, and I was. I was also clear on 290 as well. Two double A batteries so let's hope it was just a house-wide thing with the little antenna I had.
