The BAT 85 is 30 volt 0.2 Amp, 500 MHz
Look in the link i provided for the range of Schottky diodes and the replacements ;)
I figured that since I am using such a "Hot" Diode that it deserved a "decent" crystal radio wrapped around it :) .
So instead of the typical single tapped coil I want to do something a little more advanced. I'm planning on loosely coupling the antenna And perhaps the detector circuit BUT I am not finding any info on calculating the additional coils needed.
The actual tuning coil is no problem, standard math formula....now finding the info on the antenna or detector coupling coils is another story.
Most of the designs of the Dutch maker come with schematics including number of windings and diameter of the coil former.
Trial and error will bring you the optimum result, to many variables to give a detailed number.
Will have to pop off a few more to another member, will do it this week.
Soon we will have our own chrystal radio club ;)
Kewel
looking around for info and parts etc I came across some good sites.
On "that other" site somebody posted a link for coil forms at
http://www.westernsierraradio.com/products.html
But they are a bit pricey especially for a 1 trick pony.
I found another establishment with comparable forms at a lot better price along with a lot more parts
http://peeblesoriginals.com/
So far these are some of the better sites I have found
Here is a site on Crystal DXing that I haven't had a chance to go through yet
http://homepage.ntlworld.com/lapthorn/xtal.htm
Also this place has been around for ages and has a newsletter
http://www.midnightscience.com/index.html
Another useful link
http://www.crystalradiosupply.com/index1.html
This one has quite a bit of info to browse
http://www.crystalradio.net/
Continuous grommets, sometimes called caterpillar grommets, are a good, cheap way to make air wound coils.
I was told that "this" would not work or "that" was better when building crystal radios.
It is just as bad as having an "elmer".
I built 5 crystal radios following plans I could find and based on what I could find for parts.
All worked just fine.
A few months later this dufus ham shows up and asks me for "his parts".
I aks him what parts and he says the there was a charge for his advice.
I pointed out that I took none of his advice and produced the drawings I did of the material I copied.
My very first experience of US hams.
The French ham I met who showed me woodworking helped me build all of the cabinets and forms needed.
I was called into the principals office, the gent argued that I had stolen from him.
I requested a complete and detailed explanation of what it was that I had stolen.
One week later I presented the 5 complete and working crystal radios, complete with spare parts I had fabricated.
It was clear that none of this was anything like what he brought, it was so much better!
Headphones? how about 5 pairs of rebuilt ones with modern omnimagnet diaphragms?
This is a very thin sheet of very magnetic alloy that produces a massive increase in volume over common sheet steel that is used.
You will find this in some horn speakers but can make your own easy enough.
And, speaking of speakers, I built a pair of them also. ;)
I later built a "phono ocillator" with one tube, a TV sweep tube!
Proper filtering was applied and so it ran clean, but there was zero chance it was within part 15 output specs!
This was a new tube I got cheap with the idea that I was to get my ticket soon.
There was a 4 transistor circuit driving this tube, all built inside the chassis of an old 5 tube AC/DC farm radio that was rebuilt for operation from AC from a TV transformer.
You could pull the back cover and everything looked normal, transistor circuits were under the chassis and the output tube was inside the battery box.
Turn it on and it worked like any radio, to transmit you would push the volume/power knob in.
I could carry it everywhere as it looked like any radio.
I got the idea from East Germany, where converting car radios to 2 way service must have been a national pastime. ;)
Start with a simple Chrystal set, and show" see kid, no electricity and working fine" does open his eyes.
Use a decent length of antenna wire, and a good ground.
You can go from there to more sophisticated radio's adding amplification and selectivity and speaker.
But most kids turn on from seeing actually a radio work without electricity and listening to the earphone ( Hi Impedance) to the stations.
Grabbed a couple cheap plastic cutting boards from the local dollar store to make a couple spider coil forms.
planning on using 290uh for the inductance along with a 15-410pf capacitor from peebles if still in stock.
should give me plenty of leeway to cover the entire broadcast band.
The grandson's wrestling coach does woodwork. Since I don't have any hand-tools as far working dense plastic perhaps.... :)
