Not so much against the performance of the gear itself, but of some questionable construction practices.
To wit:
Spent the majority of last evening troubleshooting a problem with an R-820 which somehow "migrated" to another one. Out of a total of three that I own, two are currently on the bench getting refurbed. One was working, and the other's modules (PLL, counter, oscillators, etc) were tested one by one in the 'good' chassis to make sure they operated correctly. All except the IF-A module, which contains the various crystal filters. When I put the "suspect" radio's original IF-A board in the known good rig, said rig no longer works....and I get a nice pronounced hum through the speaker.
Tearing into things further, I find that any substantial load placed on the 14v line now causes this symptom. It was intermittent but now it's permanent.
Hmm... :chin:
Tracing back through the schematics, I find the 14v rectifier assembly (which supplies power for the entire rig) is composed of 4 discrete diodes and is mounted on the friggin' band converter board! :shock:
When I extracted said board, I find that I2R losses have enabled a couple of the diodes to partially unsolder themselves, thus reducing a full-wave bridge to a fraction of its former self.
But Wait! There's More(ons)!
Kenwood's designers also thought it would be "efficient" to use part of the board to mount a couple of solder posts that connect 115-230VAC to the rest of the rig, and one serves as a tie point for the hot end of a line-noise suppression capacitor. It's located very near the diodes, and when they heated the board up they caused the terminal to become partially unsoldered...which accelerated its own I2R thingy...
Rant:
Why in hell can't some firms eat the 35 or so cents a terminal strip costs and do a discrete bridge rectifier assembly correctly by means of mounting it directly to the chassis? Failing that, why in hell can't some firms eat the dollar or so cost for the part and use a monobloc bridge rectifier and heat-sink the damned thing to the rig's chassis?
:evil: <- This is my "Pi$$ed-off" face
/rant
As Kenwood produced it, the board's design is also somewhat of a fire hazard. I'm giving serious consideration to a redesign of the whole area... :wall
In retrospective, I suppose I was lucky that the bad board created a condition which drew my attention to a potentially serious flaw...
