What option would you exercise?
In a a new-to-me house that was formally wired for satellite dishes; I have one room in the basement that might be capable of housing a radio setup.
At one time, there was a Satellite hook-up but the 75 ohm coax has been cut at the feed point of the antenna on the roof.
Would you pull the old coax out and replace it with RG-313 or RG8X and go with a vertical multiband?
How's about ladder line out to a random length dipole type antenna?
Use the center lead of the 75 ohm coax to connect to a single long wire antenna?
Back yard is only fenced on three sides, open side being the driveway.
WWYD?
