So I get my new tuner tomorrow. A few questions...
I bought a MFJ 969 manual tuner. I also have a 50ft length of 450 ohm ladder line and a MFJ 4602 window pass through. My intent is to string up a 40m inverted V fed with the ladder line.
Does the ladder line need to be a certain length to work with the tuner if I want to work 30-10m? As the antenna will already be tuned for 40, I shouldn't need it on 40 or 15m. *sidenote* I will have to trim a couple foot section off to use the window pass through and connect to the tuner inside the house.
What kind of losses can I expect if I use *random* length of ladder line and on what bands?
Will I need any sort of Balun to get it to work? I believe the 969 has a 4:1 built in balun but I don't know if that will be enough or if it can be bypassed.
If I do happen to screw up cutting the dipole for 40m, will the tuner be able to take care of any mismatch? (Remembering my other disasters in making dipoles, I DO have new coax as well but thinking ladder line will be easier to work with... I hope anyway)
