Where do you get yours?
http://www.thewireman.com/
I'm particularly fond of their product #531.
Home Despot, regular old 14 AWG THHN copper wire by the 500 foot spool. Works fine for the most part, although it does stretch over time so if you can find (and afford) multi-strand copper-clad steel wire, that's the way to go.
I get my copper wire from the local power company. For some reason, they use lots of it in the street lamps.
Attachment 12750
Really though, I still have some rolls of stranded copper wire that I bought from HRO Atlanta. Like the Pope, I also use 14 AWG THHN copper wire from a local electrical supply house -- as mentioned, it does have some stretching issues.
I've bought it by the spool at the local hardware. Pulled a spool of 8ga out of the work dumpster a few years ago. I asked, "Are you sure you want to throw this away?"
Get hold of some old telegraph wire. It works great and is very strong.
Old transformers.
Cleaned out a shop that sold anything from audi televisions and washing machines and did installations in electrics and grounding for lightning stuff,
Got all the wire out for testing the ( repaired) audio and televisions for the guys that bought the content of the shop, 10,000 feet of wire in supply here, 3000 feet of which is now my radial field for the inverted L.
Gave away some of it to poor hams that needed some wire, must have 5000 feet left for projects.
Included some shielded wire for microphones and lots of 300 foot rolls of 230 volt 16 amp installation wire, grounding wire some large copper clamps for lightning arrestors etc.
Used 17 grounding stakes here in the young seaclay to make sure I have a decent ground.
Seems I succeeded in that since my electrical installation was tested last year and the guy really tapped his electronic meter because he couold not believe the low resistance I had, grounds are all interconnected to the house ground.
