What would you consider to be the top 10 must have hobby/experimenters transistors, diodes, or other semiconductor/IC's you would want in your parts box? 8)
1n4007 and/or 1n5408 , 1KV @ 1A , and at 3A , respectively . MMBT2222a , surface mount equivalent to the classic NPN.
From the age of 12 i salvaged parts from good PCB's and must have 20.000+ transistors from all edges of the world, all tested and good.
I realised i will never use them in the rest of my life, so i started a few years back to help out Ham's that needed certain parts to send them a few of my supply.
I donated my tube collection to a museum that rebuilds old radio's or transmitters....
Having cleared out a repair shop the last month, the supply only went up, though much parts were donated to the group that doees the maintenance of our repeaters/beacons.
Standard range resistors, C's,Schottky diodes i was able to help a few members here and some at Qrz.
If you do anything with RF, standard range inductors and chokes are a must.
Digital?
Be well-stocked in the 74xx, 74LSxx and 40xx lines.
I have a bunch (and I do mean a BUNCH) of caps, precision half-watt resistors and the like; I'll never use all of the particular values I have on-hand. A goodly-sized assortment is yours for the cost of postage.
78Lxx voltage regulators, in 5v, 12v and adjustable type.
Careful, when I get a little better up I might take you up on that offer, Steve (Mot) too if I am not too late by then...
Got Wifoid 1.0 a little miffed at me this morning. Started a little "project" spread across part of the the living room floor last night that I need to finish up.
I have one of those large Plano fishing boxes I grabbed a several months ago when I outgrew the smaller tackle box ITT issued when I first started.
I was up past 2 am "Customizing" one of the trays so some of my stuff fit better. Who knew that nibbling out a few compartment dividers using my small wire stripper and a pair of dykes could be so time consuming and messy.
Anyhoo I have 2 of those 1/2w resistor assortment packs, 1 came with the kit, the other I got from the school chair as reimbursement for some antennas from radio shack I needed on a couple of those radios for the blind I was fixing in the lab.
I also have a bag of 1/4w assorted from "the shack" and a 1lb pipe tobacco bag of 1-2w unsorted resistors that "Skool" was throwing out that I grabbed :)
In the course of 5 quarters, all those little resistors that never seem to get put back in their plastic baggies congregate in the oddest places, You know, The spots you never check so you end up digging another one out of the baggie?
So I am working on sorting them out since they are the ones most commonly used in lab class, And giving each one a baggie of it's own instead of 5 different values in a bag like they were originally packaged in a little box.
The school kit didn't have a whole lot of parts except for the resistors and a few project kits for soldering practice.
They only had a few of the different capacitors, A few IC's and inductors (Skimpy bastiges). So Thats one thing I need to work on along with Semis :)
Went through the hand tools they had along with what I already had and sorted 1 each of the best example into the box along with my hot glue gun & desoldering iron.
Turning into a real project of it's own, But I'll be somewhat organized If I get the chance to return to school.
http://i228.photobucket.com/albums/e...dio/Toybox.jpg
Taking a smoke break
Wifoids Grandson Was bored so he decided to help. (he doesn't realize he is starting to learn the resistor color code) 8yrs old ADHD :)
OP-07, 22V10 for glue logic, microcontroller of choice like MSP-430, Parallax Propeller, etc.
