4 Attachment(s)
New 2 meter EME amplifier..
Hi all...About a month ago I was asked if I could build a 2 meter RF amplifier capable of delivering 400 watts EME data...This means one minute on and 1 minute off data transmissions, quite a task for any amplifier...It needed to be reasonably compact and straight forward and practical..
Most of my amplifier experience is with HF amplifiers, having built more than 50 over these past few years so I was able to come up with a few ideas and apply them to this project..
I chose a Russian GS-31B triode for the job....This tube has a 1kw anode dissipation, grid dissipation of 26 watts and a maximum cathode current of 1.4 amps....I chose an anode voltage under load of 2.5kvdc...
The next problem to solve was how to blow off the 400 watts of plate dissipation whilst delivering 400 watts continuous RF data....The GS-31B has a solid cast alloy removable finned heat sink type cooler...The air through this tube is basically free flow with little to no back pressure...After a few inquiry's from some experienced ham buddy's I chose a new EBM Papst 4650X all metal boxer fan for the job..I had to import some from the US at considerable cost, mainly postage...
I chose a very straight forward T output network using a machined aluminum disc capacitor for tuning and I then machined up an adjustable coaxial pickup for loading....This pickup is a set and forget feature...
The power supply is a conventionial voltage doubling unit using a large toroidal HT transformer especially made for this job...The HT supply is 3kv peak dropping to 2750vdc under an 800ma load...I hand wound a filament transformer, 12.8 volts @ 4 amps and used a commercial small tranny for the 24 volt relay supply..
The amplifier is simple using manual switch on for the heaters and HT supply and has a variable bias control..Anode and Grid current are monitored using a pair of cheap but good quality meters...I made my own scales to suit the job...
The complete amplifier is hand made from the case to the front panel finish and the various boards wiring etc...The job probably took around 30 hours to complete over the past month....It has been an enjoyable project and gained me some new experience and knowledge which I will apply to the next project....
Simple specs....The amplifier will easily run 1kw output SSB and CW..For 400 watts data the amplifier runs loaded 2700vdc @ 300ma...As the efficiency is nearer 55% there is some spare overhead....Weight 18kg... Case 18" wide x 16" deep x 6.5"high
Enjoy the construction pictures...
Bob..VK3ZL..
4 Attachment(s)
More construction pics..These show the case under construction, the tube socket and input T network shielded box, and the finished amplifier module...The complete module can be easily removed from the amplifier case simply disconnecting HT, Filament and B minus wires and coax connectors....
Bob..VK3ZL..
