A 1/4 wave vertical dipole doesn't work so hot for 2 meters. I could never get the thing tuned to the ham band (It "liked" 129 MHz or so best), and had a really wonky impedance that I could never get match.
I found a 1/4 dipole design somewhere, and the web page said,"It works great!". That might be accurate, but not with my system until I get the coax replaced with something other than 75 Ohm cable.
So, back to my "tried and true" antenna for 2 meters: The 1/4 wave droopy ground plane. I'm taking my time building this one, because I killed a length of coax by not sealing with well enough, and it leached water down the entire length. One good thing? This spool of cable cost me about $10 for 1000 ft.
So, this ground plane will be "well engineered" and not "ad hoc" as has been my past designs. I think for now, I can't beat the 1/4 ground plane. A beam is the next "step up", but I have to have an omni design. Have to complete this by week's end so I can try to get a new HF antenna designed, built, and up before the first snow.
