Here is a plumper who suggests a whole wheat alternative for pizza crust.
I like the idea but I would go even coarser and grainier. About 12 grains and whole flax seeds.
Yes, it's a golden day to be facetious.
Cleeky Cleeky
Cleeky Cleeky
I don't know about the courser dough and the flax seeds. To be authentic pizza has to be baked in a coal fired oven at around 700-800 degrees. Around the edges and on the bottom the crust should be somewhat crispy with a few burned spots here and there. i don;t know if the flax seeds would lend a very good flavour at those temps.
Good point John but, as you can see from the video, she is as well as I am, using the standard home oven. That maxes out at 500 degree F which is more than I need indoors.
Question: When you decide to cook a pizza, do you use a traditional pizza oven or do you improvise and make the most of what is on hand.
Here's and idea. You can still get that burnt bottom effect on the stove top.
Around here I don't even try to cook my own pizza. To make it right you need a brick or stone oven fired with anthracite coal. the whole trick is to bake it fast at high temp. Fortunately we have two places nearby that make it that way. Otherwise I'd have to either build a brick or stone oven, improvise with a conventional oven or, do without.
Bake bake bake
First off, I actually prefer that generic "pizza" that a lot of places serve.
Second, healthy pizza? by the very thought it is not authentic, this is the Los Vegas style Paris, not intended to be real.
Disney world Italian pizza.
