Guy may have bricked his IC-7800 due to a faulty firmware upgrade. One hopes this was an isolated incident:
http://forums.qrz.com/showthread.php?t=243439
Aside from the main topic, interesting callsign the fellow has.
If that happened to my 10 grand radio, I'd sure be pissed!
I have not a clue, but I would hope it is an isolated issue.
IBTETR [In Before The Eventual Toyota Remark] :stirpot:
The problem is in the series of pipes and tunnels that radio uses. Isolating the clog will be the hat trick.Quote:
Originally Posted by N5RLR
because i had to preserve this ...Quote:
Originally Posted by KA5PIU
I don't know about ICOM, but one would think that if the firmware chip had been messed up, and the radio turned into a brick, wouldn't replacing the chip with a "new" one flashed from the factory un-brick the radio? Or is that too obvious (or is the chip not accessible in such a way)?
two things...
1. Sucks to be him! :boohoo:
2. If you can afford a 10K radio, you can afford to get it un-fuxxord. Dumass...he was probably using linux or an Ipad...
If the chip cannot be readily desoldered or goes obsolete...you run the math.Quote:
Originally Posted by W3WN
